Hi, I am in the final stages of my oven build, I decided to go against all odds and built a 70 cm, 1/3 cut firebricks (results a 7x6x11 brick, and a 7 cm deep dome) mortared with beautiful purple homebrew (used white Portland and the dust from the cutting of the bricks). Donīt worry, I will buttress when closing the dome.
I believe that by trying to maximize the minimum space used, I did not leave enough clearance for the flue. Any recommendations? I don’t think I can safely get it to lay in place because of how I made the dome. I am planning on covering with a blanket. Here are some pictures and I would be eternally grateful for any ideas.
My instinct is to sort of make a semi beaver/squirrel tail and send it a few cm back (my fear is that even though the vent is not too heavy, it is measuring about 1 meter SS will fall forward).
Thanks.
EDIT: The keystone at the entry arch is the mot outer part of the dome.
Thanks.
