1. I noticed most people use the chimney kit and do not build it out of bricks. Is there anything wrong with building it out of bricks? Also do I need to have some type of insert inside the brick frame? I have seen some posts discussing weight issues, but if I build it up enough should it work ok?
2. Also now that my oven is getting closer to being complete, is there special wood that I should use when curing what about cooking? Also does anyone have a step by step guide to cook with the oven?. I am not clear on the procedure.
I think its:
Build fire
Wait 1 hour
move fire to the side
add pizza?
3. I noticed everyone makes their own dough is this required? I would like to make my own dough but I am a true novice.
Thank you!
-Sean
I think its:
Build fire
Wait 1 hour
add pizza?
Thank you!
-Sean
