Sounds like your wire should do the trick. I get my stainless extract fibres from Antec
The reason I use motor oil diluted with kero is so I don't end up with the casting coated in oil, it comes away pretty clean, but I do apply it fairly sparingly. Unfortunately plaster is very absorbent, so the wax is probably a good idea to seal it first, then apply the oil. If you're not wanting to make anything stick to the casting then it doesn't matter. If you are planning to either cover the flue gallery casting in blanket or vermicrete then you won't even need to clean the surface.
But I do have pics of the back in the box, ready to be repaired.
