So I’m planning my first new build. 40” oven with an 16-18” dome using a combination of arch bricks. I’d like to do something with a thicker floor for retained heat. Was gonna do 3” of foamglas and 1” CaSil and a 4” floor. Here’s my question:
1-was thinking of using IFB under the dome and surrounding the foamglas/CaSil. This would require 3 rows. Should i mortar the first row down to the concrete counter OR should i let it sit dry and allow the dome to “move” as it expands and contracts OR mortar that first row down?
2-instead of using IFB surround the space around the floor/below the dome extension out the Foamglas or CaSil essentially letting the floor “sit” in a well of insulation and let the dome sit directly on top of the insulation. This would have the added benefit of not having to cut so much IFB.
thanks
Mike
thanks
Mike
