Coating the outside of the dome prior to insulation
Re: Coating the outside of the dome prior to insulation
Have you brought it up to temp yet? I had a few minor cracks, so I went ahead and covered it up. If you develop some massive cracks, you may want the ability to fill them in.
I coated mine all over because I was sloppy about "backfilling" while I was building. So I used a bag to force it into the gaps, and then just slathered it on the outside to tidy it up a bit- I didn't have a saw that cut the whole way thru bricks, so I had a lot of broken ugly edges I didn't want to tear up my blanket with.
It's all about the mass- I think you'll be ok if you've been better than I was about filling as you go.
