I am soon to start the curing process in my completed oven taking care to use the procedure for gradual heating and multiple, increasingly larger, fires. Looking at other threads showing cracks during initial firing and reading about different practices w.r.t. having insulation on or off during the curing part I can see the advantage of being able to spot cracks with the insulation off. But, will the risk of cracking increase with the insulation off due to higher temperature gradients through the bricks and mortar? The temp. gradient causes stress which again causes cracks. With a slow fire the bricks and mortar should have a better chance to equalise in temperature with less gradients? I guess that holds for all later firing as well, - start a bit slow and increase the fire as the temperature climbs?
regards from Karl
regards from Karl
