My Father had someone build him a WFO. After some investigating I came to the conclusion that it was created with a major flaw - no insulation.
Thanks to this forum, I have been reading as much as I can over the last couple of days and I am trying to make improvement to the current design. I know there are few options but I hope this is not a lost cause.
Any recommendations would be appreciated.
First the design...
The Oven was created on a cement slab of about 5-6 inches thick. The fire brick was laid with mortar directly on the slab. The bricks were joined with a high temp premixed glue. The dome was constructed directly on the fire brick bed. Once again the joints on the inside of the dome are being held together with the high temp glue, the larger gaps to the outside of the dome are filled with mortar.
Once the dome was completed it was covered with 2" of mortar.
Currently the dome is exposed (phew!) and this will allow me to insulate the dome. I purchased locally in Toronto a 1" ceramic blanket that I plan on placing directly on top of the dome. I also bought 1 bag (4 cubic feet) of vermiculite (I will probably need more) that I plan on placing on top of the blanket. I am not sure if I can place it as is or if I should use some type of mix configuration. Once this is done, I will ask them to continue to close off the oven.
As for the oven floor, I realize that the floor will not maintain heat in its current state. I am trying to figure out the best solution.
I can think of two options....
1) insulate under the concrete slab. This may help a little but my limited research suggests that this might not be that helpful.
2) purchase 2" insulating board and place it above the current firebrick and then place another course of fire brick on top. Cutting the firebrick to fit perfectly might be a problem but I think I will be able to manage. I also realize that I will be eliminating aprox. 4-5 inches of height. I think the oven can easily accommodate this without causing a problem.
Any suggestions would be greatly appreciated.
Oh, I almost forgot... What is the best way to secure the insulating blanket to the dome? I see some people use chicken wire. What other methods are there?
First the design...
