Does my oven need a chimney?
  • PerryPizza
    • Sep 2008
    • 90
    I've been wanting to build a pizza oven for ages and some time ago I saw an oven built without a chimney, just a simple dome with a door. My oven will be built outside, so I was wondering if the chimney is really necessary, or is it like a woodburner where the hot chimney sucks the air into the fire to get it really going?
    My rustic oven;
    http://www.fornobravo.com/forum/f8/p...oven-6770.html
    sigpic
  • CanuckJim
    • Jan 2006
    • 1480
    Re: Does my oven need a chimney?
    Ovens have certainly been built that way, but I'd have to say that they will not draw properly or create the desired venturi effect needed for complete combustion and really HOT fires. Add to that the inevitable smoke staining on the front of the oven. Build a chimney.
    Jim
    • PerryPizza
      • Sep 2008
      • 90
      Thanks Jim, I have struggled in the past with a woodburner which was fitted with a down-sized flue so I know what you mean. I have to say I quite like the smoke staining effect though!!
      My rustic oven;
      sigpic
      • Wiley
        • Mar 2008
        • 804
        PerryPizza, I have two neighbors with wood fired ovens that were built without chimneys. The biggest drawback I have noticed is not the soot staining but when they are being fired the flames (that those of us have going up the chimney) bend out and up the front of the oven. The most recently viewed one was at my neighbor's birthday party this past weekend. This particular oven was also built without any landing and was in my opinion quite dangerous to the unwary when firing up. The owner had stand guard to keep back the curious who wanted to get close and "see". He usually uses if for bread not for pizza and doesn't have crowds.
        Neither oven has any problem with airflow and they both were built with the entry to interior dome height proportion very close to 63%. One is sort of on the French Canadian lines where it's footprint is an oval and the other is like mine.. a hemisphere/dome.
        Wiley
        • Frances
          • Aug 2007
          • 2186
          Its actually quite easy to get the staining effect with a chimney...
          • Les
            • Sep 2005
            • 2945
            Wiley,
            These ovens vent out of the front opening? That does sound dangerous. The title is "does my oven need a chimney" - I'm sure they would work without one, but I assumed that there would at least be a hole for venting. I discover something new here everyday....
            • Ken524
              • May 2007
              • 1655
              1000F heat and flames coming out the front opening? No thanks. Build a chimney (it's not too hard).
              Ken H. - Kentucky
              42" Pompeii
              • krosskraft
                • Sep 2007
                • 174
                Does my oven need a chimney? Do I need eyebrows? Build a chimney. I even added height to my chimney because it was close to the house, but it draws great, and I rarely choke on any smoke while it is heating up.
                • james
                  Brick Oven Merchant
                  • Mar 2005
                  • 4648
                  To summarize. Yes, you need a chimney. :-)
                  But seriously, you really do. It not only keeps smoke, fire and hot air away from your eyebrows, it also creates the draw effect that moves hot air effectively inside your oven, creating natural convection which makes your oven heat up and cook better.
                  • PerryPizza
                    • Sep 2008
                    • 90
                    Thanks for the responses, I will build a chimney!
                    The truth is I had always intended to, although I'd still like to hear from anyone who actually uses an oven without a chimney just out of curiosity. These certainly seem to be in the minority amongst the people on this forum! It is interesting that Wily has two neighbors who use this kind of oven, I can just imagine the scenario he describes...
                    My rustic oven;
                    sigpic
                    • james
                      Brick Oven Merchant
                      • Mar 2005
                      • 4648
                      I think it's like a car without a windshield (or windscreen, depending on your version of English). It still works, but the experience just isn't the same.
                      There is no upside to not having one -- the only reason to not have a chimney is either expense or effort.
