Hi, i have decided to take the plunge and build one of these Pompeii Brick ovens!!
So far i have dug a space for a slab and boxed it up, it is 3m x 2m x 0.14m, i plan to have a 1m landing at the front (see diagram)
My most immediate design question is whether an opening of over 1m in the block support stand will be too large and may not be strong enough to hold the the weight of the oven. I'm planing on just using angled steel as a lintel to bridge the gap.
My second design query is: is it possible to build the dome from refractory concrete, ie will it hold enough heat and work ok as an oven.
Thanks in advance for anyone that can help me
