I have a 14" chop saw with an abrasive blade. I have been experimenting on how to cut my firebricks and have found that if I just score it top and bottom with the saw and then tap it with a rubber mallet that it breaks in two pretty easy. This would be much less sawing and dust. I end up with two halves with one "bad" edge on each half brick. Since this edge would be facing out from the oven interior, seems like it wouldn't matter.
Has anyone done something similar with OK results? Or am I putting stress in the brick that might cause it to fracture later?
Thanks.
Thanks.
