Firebrick in So Cal
  • Firebrick in So Cal
    Does anyone know a source of firebrick in Southern California.
    Where can I buy some?
    Thx
    Google will find Fire Bricks; Search within results.
    Thx
    (M) I did a Google Search with the following keywords:
    Results 1 - 10 of about 7,620,000 for bricks southern california. (0.42 seconds)
    Try clicking on http://www.google.com/search?hl=en&l...ia&btnG=Search
    Once that opens, go to the bottom of the page: Search within results
    and enter the name of your city, e.g. Anaheim, or Thousand Oaks.
    I'm sure there are many masonry supply dealers available to you. But be certain you get the right kind of brick. There is a primer on this forum to guide you at:
    Ciao,
    Marcel
      Thanks Marcel,
      I had tried that several times and still no luck.
      I have not started yet and I am planning out my build. I was going to build a barrel type oven until I found this site.
      I am eve tempted to buy the oven and just put it on a base.
