4 years in the making - 42" dome
  • #61
    Re: 4 years in the making - 42" dome
    http://www.youtube.com/watch?v=fiGy2ZA9xas
    My first evening fire - the daytime fire did not turn out
    Follow my build Chris' WFO
    • #62
      Yesterday I burned some olive branches that had not been disposed of as of yet. I did get some video. They burned down nicely to some nice embers. Fire itself lasted about 1 hour (had a view while watching the Green Bay game.)
      This AM, I am using a propane fueled weed burner on a med-low flame for a few hours to get the temp up. Treating this as my 350F fire. I may let it go longer as my afternoon meeting was canceled - gotta love attorneys.
      Tomorrow, I plan to use some mesquite and really get the temp up. At this rate, we will be having Christmas Pizza. Will be heading down to the wood yard in a couple days.
      This anticipation thing is driving me crazy!
      • #63
        Here is a picture of my weed burner in action. You may ask why the brick is in there? Well, I did not have it in there and due to flame impingement on the soldier course, I had a crack develop.
        This fire has been going for a while and you can see the impingement brick glowing when I cranked the burner on high - yowee!
        The bricks up front are to protect the interior as we are looking at rain yet again. Out in the farmlands I live in, the winds swirl and kick up really easy. The added effect is that I have a bunch of heat held in. I cover the hole after firing.
        Due to that place I go to during the day, a wood run has been impractical. So, I may just send my teenager to get the carbonaceous material. "Hey dad, they had a special on pine today and I saved you some money!" Fortunately, he follows direction pretty well
        • #64
          I've burned a lot of two by four fragments in my oven. There's really nothing objectionable about burning conifers in WFOs, unlike in wood stoves where the smoldering fires promote creosote buildup. You'll want some hardwood to keep the fire burning while cooking, as pine spits and throws cinders, but for heating up your oven pine works fine.
          • #65
            Oh the first full wood fire - how pretty. One day closer to the pizza homage!
            I am just surprised at the physics of the fire! In the last picture, you can see flames lapping out my chimney - uh, I guess a little too much wood. And yes, I know I need to start cleaning up!
            • #66
              Need to get an answer on Crack repair:
              When should I perform?
              Should I grind out both inside and outside and tuck point the mortar?
              Thanks in advance
              • #67
                Just finished my build last weekend, I still have all of the receipts in the closet. We have not quite decided if we really want to know... $ $ $
                Once you complete you build you may not want to know either. ; )
                • #68
                  I am under $500 at this point, even with extra pearlite. I have not even thought about the cost of the enclosure
                  • #69
                    "you can see flames lapping out my chimney"
                    That's what you want. If anything your fire is too small.
                    • #70
                      Costs here are about X5. ie each firebrick is NZ$ 5 or US $ 7, so consider yourself fortunate.
                      At least the labour involved was the same pricce!
                      • #71
                        First off - Merry Christmas to all!
                        I thought catching that on film was cool + I do not remember other pictures with the flames a roaring. This fore was made using bagged firewood - typically really dry pine, so getting the flames that high was not too hard. Stoking the fire caused me to lose a few knuckle hairs. Tonight I am using hickory for the pizza's. Bloody expensive around here, but it is well seasoned and in large chunk for for easy stoking. I am also planning on my revenge of a nasty mesquite tree I used to have - last segment from cutting down will also be in the fire tonight.
                        As for low cost methods on building the oven, yes, I used my slave labor (14 yr old who grumbled several occasions when running the power machinery- "Daaad, I was playing Xbox" in a pubescent boy voice.
                        As previously mentioned, I was really fortunate as I was able to get my brick for free. The stuff is about 100 years old and from one of 3 boilers. Mix of the bricks went from medium to high (and boy can you tell the difference when cutting!)
                        If folks are on a budget, get a hold of your local building department and find out about demolition permits which have been pulled/filed. Then call the demo company. Most demo companies will gladly give you any fire brick from projects because it saves them $$ in disposal. I am doing the same with red brick from a friends house getting demo'd in a month. Nice thing is that the mortar chips off pretty easily.
                        • #72
                          ....snip.....If folks are on a budget, get a hold of your local building department and find out about demolition permits which have been pulled/filed. Then call the demo company. Most demo companies will gladly give you any fire brick from projects because it saves them $$ in disposal. I am doing the same with red brick from a friends house getting demo'd in a month. Nice thing is that the mortar chips off pretty easily.
                          Merry Christmas to you too
                          The demo idea is a good one. Cleaning brick takes a knack to do without breaking the bricks, but you'll get better as you practice. A local brick kiln was demolished here in Texas, USA, I was able to get a lot of bricks....Not cheap, but saved a little money. Don't know yet whether they are easy or hard to cut. Then, my brick mason was here yesterday and said he had a stack of new firebricks he'd sell for half what I paid for the used bricks....That is the way life is, timing is EVERYTHING!
                          Lee B.
                          DFW area, Texas, USA
                          • #73
                            Last's nights party was a success. Used pine to start the fire and hickory and mesquite to build the coal bed. Learned a lot from the firing. 1. I need to insulate it 2. allow for about 2.5 hours to saturate the bricks with heat 3. more coals 4. Not to trust brother in law to mess with the crusts - his stuck to the cardboard 'cuz he flipped it over without rice flour, which worked like a champ! 5. need proper tools - the large pizza peel caused problems rotating pizzas in the oven and my modded brass grill brush did a good job, just slow due to the size. 6. Use more wood at the beginning to build coals 7. Dont tell the neighbors about pizza oven as either some wanted a pizza, while others thought the black smoke meant the cardinals were meeting to elect a new Pope
                            • #74
                              Congratulations. You have product. I wish i could be confident that smoke will not be an issue. I am in an urban environment and it will not go down well with the neighbours.
                              • #75
                                Hey John,
                                First off, thanks.
                                As for the smoke. I live in a residential area, just low density - everyone is on an acre in my neck of the woods.
                                The big challenge is that we have no burn days with folks from the Air Quality District driving around. On Christmas eve, it was a no burn day. However, I used the food preparation exemption - cant force me not to eat, eh?
                                Most Air Quality laws/rules I have reviewed around the world (I was an environmental consultant) have an exemption of smoke for food preparation, just need to dig a bit into the regulations. Neighbor complaints, that is another story. Offer a pizza and most are happy to let it go. If they are a persistent pain, give them brownies with phenolphthalein in them. Works better than exlax. Plus you can say that you did not hide exlax in the brownies - LOL. Better life through chemistry.
                                CW
