I?m going to pour my vermiculite concrete layer this weekend. I poured test sample of the vermiculite and noticed areas of small air pockets. Should I be concerned with moisture or air pocket in the bottom insulation layer that may expand later when heat is applied? Perhaps it is assumed that hot air and steam slowly works its way out thru the brick floor and is not a problem.
Cheers,
Cheers,
