Re: Bill's Northwest Pizza Oven
Lee, the door with the thermometer is a door I use when I want to have a lot of insulation and retain heat for long periods of time. It has 2 inches of ceramic board sandwiched in it and works well. The old door - AL tape over plywood is the one I most recently replaced with a sturdier version. it is used to cover the opening when I'm not using the oven or to use when I need air to circulate in when smoking meats. Should withstand heat better than the old one.
