I'm planning on pouring the hearth this weekend and I have a couple of detail questions.
First, the local garden center can provide 8 cu ft of perlite(they only have 2 bags left) or 10+ cu ft of vermiculite (medium). So should I go with the vermiculite or perlite?
Second, I am thinking about putting a slot in the hearth (I'm thinking 1.5 inches by 12 inches) so I can rake/brush the ashes into a metal container underneath the hearth. My concerns are: what to use to block out the opening when I pour the hearth that I can easily remove once the concrete is cured? - would a piece of 2 X wood work or would that become a permanment part of the hearth. Also, is an ash slot a good idea? would a different size be better?
Tom
Tom
