The base of my oven is made of ciderblock, with concrete lintels spanning the void in between.
Around the perimeter of the base, I will lay a shallow wall of standard bricks, set on their narrow side. This will create a wall 4" or so high. It will be mortared to the base.
Inside the wall, on the bottom (directly on top of the slag lintels of the base) I will lay down a 2" layer of high density fiberfrax board. This eliminates the need for vermiculte cement. The board will be cut precisely so there is no gap. It fits in snug.
On top of this, I will place the firebricks for my hearth, without mortar. They are held in place by the standard brick wall. Again, they will fit in snugly (I may have to cut them to get them to fit properly).
Voila! Two and one half inches of firebrick, with two inches of fiberfrax insulation underneath. The shallow brick wall will keep everything from sliding side to side, and bricks are easily replaced if they break. They are not mortared in, so if they need to expand, they can.
Any problems with this approach? The only possible problem I can see is that the brick wall may not allow the firebricks to expand. To address that, I'll simply add a small gap (maybe 1/8")
Of course, I'll have to cover any exposed firebrick on the hearth that is not covered by the oven dome, but that's easy (I think).
Thanks,
- Fio
Thanks,
- Fio
