My Mason decided ondoing a masonry chimney rather then the 8" pipe. Isthis ok. Height wise I have read if the ovenis 36"deep then the chimney should be at least that in height. Any concerns if itis 2 inches short not including the cap of course? Also If the chimney is not 8" square is that a problem? Again he made this thing taper in like a fireplace chimney. Just making sure it will still draw outside the dome.
Steve
Steve
