Re: Finding the Pompeii Oven Plans
There are no dimensioned drawings, too many variables and variations.
Hello UKOriginally posted by thewibbit View PostHi.. on the main website I have tried to register to get the plans but the list of countries ends halfway through 'c' so I can't register in the UK. Any ideas? I have a friends address in the US.. could I register with that but a .co.uk email?
If you google search "pompeii oven plans" the second result down should be the Forno Bravo plans in a .PDF format. I'll paste the link below.
http://www.fornobravo.com/support/in...achment/22/800
Just what kind of plans are you looking for?Originally posted by smignogna View PostIf anyone drew up some plans would they mind sharing them with the group? Thanks!
I did some myself just to ask for help and help with my layout.
I could fully develop them if it would help.
Real plans would have saved myself and I suppose everyone a ton of time and agravation. I drew up some plans but they are in no way complete.
me too. i was a bit disappointed
I guess a stupid question... I have downloaded a pdf that is call instructions but I don't seem to be able to locate"plans". I'm a carpenter and expected dimensioned drawing and such.
for the printable pdf you need to register, but sadly the list of countries in the registery form is very limited..
I'll try again from another PC, but I opened the zip file and it was empty
i want to have a set of plans pre-printed,how can i do?
thanks.
How can I get a set of plans pre-printed?Any suggestions?Thanks.
Mike/Chicago
Thanks for asking - I was lamtening to a freindly Canadian and he said doing what I am doing is like herding ants. It is frustrating at times and is alltogether taking too much time to complete. The first draft is is up to putting on the chimney & insulation. The first draft will not have many pictures but rather placeholders for where pics will go.
Getting into the inulsation I think the system may need to be pre cured depending on the type of enclosure. If you do a "house" enclosure then the moisture (steam) will be able to escape like a normal house. I think that if you are doing an igloo enclosure (which is water tight) then you really need to do your fires before you seal the structre. Depending on the type of insulation this may be after you have applied the 1/2 to 2 inch butter (fire cement) for extra mass (if your desuire is to also have an oven that will hold heat for longer periods). If you are using the fiber insulation and then douing stucco over it you probably should let the oven cure a week or two and then fire it. Cover it with insulation and the stucco and then cure it again and also do a modified series of curing fires.
I need to pose this to James and the community in another thread so that this one does not get hijacked.
How is this project coming along?
