Brick counts
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    Brick counts
    I have been thinking about the brick and mortar counts in the Pompeii Oven eBook, and wanted to see how accurate our Materials Lists are. So I need your help. Can you scan back through your notes (or memory) and tell us a close brick and mortar count and the size of your oven.
    Thanks!
    The Pompeii Oven eBook calls for the following:
    42"/110cm
    65 bricks for the floor
    135 bricks for the dome
    30 bricks for the vent
    150-200lbs mortar
    36"/90cm
    60 bricks for the floor
    120 bricks for the dome
    130-180bls mortar
    Thanks all!
    Pizza Ovens
    Outdoor Fireplaces
  • Les
    • Sep 2005
    • 2945
    Re: Brick counts
    James - I recall buying 275 bricks for my 42 inch (may be off because of old timers). I tossed a ton of scrap because of the cuts.
    Les...
    • Gromit
      • Mar 2009
      • 117
      Re: Brick counts
      I am not really answering the question since I have built no oven; however, I have dusted off my high-school geometry. The surface area of a hemisphere is r^2*2*pi.
      36" =~ 2,036 SQIN =~ 91 bricks for dome
      42" =~ 2,771 SQIN =~ 123 bricks
      If one is tapering the bricks, then use the surface area of the outer dome to arrive at the maximum number of bricks that could be used:
      45" =~ 3,181 SQIN =~ 142 bricks
      51" =~ 4,086 SQIN =~ 181 bricks
      If you use more bricks than that, then they are ending up somewhere else besides the dome!
      I am very interested in the REAL answer to this question, because I will begin my own oven soon.
      -David
      -David
      • Jed
        • Apr 2008
        • 428
        Re: Brick counts
        Hey All,
        Seams to me that I brought home 175 fire brick. There were maybe 8 left over after the build, and I used some red brick building the vent... On a 36 inch Pompeii.
        JED
        • bimbo
          • Jul 2008
          • 104
          Re: Brick counts
          give me a couple of weeks and i should be able to give you an answer
          Real men cook with fire
          My Oven and Fireplace Build
          • egalecki
            • Mar 2008
            • 1049
            Re: Brick counts
            I remember buying 200 firebrick for my 36, and I have maybe 5 or 6 whole ones left. I did reuse a lot of my offcuts for wedges, etc. I hate to waste.
            Elizabeth
            • Modthyrth
              • Mar 2008
              • 359
              Re: Brick counts
              I built a 42" dome, as basic as you can get--lintels, no angle cuts.
              I bought 225 firebricks (brought 224 home, they miscounted by 1),
              used 24 for the firepit,
              and have 11 left over.
              So it looks like the oven took 189 bricks.
              I think the estimates in the plans would have worked perfectly for me, if I hadn't stolen the 24 bricks for the firepit.
              Nikki
              • TonyBatty
                • Aug 2008
                • 14
                Re: Brick counts
                I still have to complete the small chimney and front arch but I expect to use all of the 200 bricks bricks I ordered for my 42" Pompeii
                TonyB
                Visit my Blog at www.batty.me.uk
                • Ken524
                  • May 2007
                  • 1655
                  Re: Brick counts
                  42" Pompeii - All bricks custom cut/tapered
                  295 Medium Duty firebricks
                  2.5 bags of HeatStop 50 (50 lbs bags)
                  Ken H. - Kentucky
                  42" Pompeii
                  • james
                    Brick Oven Merchant
                    • Mar 2005
                    • 4648
                    Re: Brick counts
                    Thanks Ken,
                    Do you have a theory on why you went to a higher brick count than some other builders?
                    Also, if anyone else has mortar counts, that would be helpful as well.
                    Thanks!
                    Pizza Ovens
                    Outdoor Fireplaces
                    • Modthyrth
                      • Mar 2008
                      • 359
                      Re: Brick counts
                      Two full bags of refractory mortar (I used Thermal Ceramics brand), and I did homebrew for the rest. Three bags would have covered my needs, I'm pretty sure.
                      Nikki
                      • james
                        Brick Oven Merchant
                        • Mar 2005
                        • 4648
                        Re: Brick counts
                        I'm guessing that's 3x50lb. Perfect. Thanks.
                        Pizza Ovens
                        Outdoor Fireplaces
                        • Modthyrth
                          • Mar 2008
                          • 359
                          #13
                          Re: Brick counts
                          Oops--salient detail. Yes, 50lb bags.
                          Nikki
                          • Ken524
                            • May 2007
                            • 1655
                            #14
                            Re: Brick counts
                            Originally posted by james
                            Thanks Ken,
                            Yes... Les and I were within 20 bricks and we both custom cut each brick. Custom cutting/tapering definitely requires more bricks.
                            Ken H. - Kentucky
                            42" Pompeii
                            • peterdin
                              • May 2009
                              • 1
                              #15
                              Re: Brick counts
                              for 80 cm (internal diameter oven)
                              120 firebricks for floor and dome, bought 14 extra, so in total 134 fire bricks.
                              Used up 3 1/4 bags (25Kg) fire mortar.
