dome rings combining with chimney brick
  • smithgardens
    • Apr 2006
    • 4
    we have started laying the first layers of the dome and have choosen to build the chiminey with an arch design. for the layers of brick that intersect with the chimney bricks, is it best to custom cut each of these bricks to fit in line with the dome? or is it best to build the dome separate from the chimney? the degree of tilt of the chimney arch and the cooking dome are different and prove to be a little difficult in lining them up without doing some custom work.
  • melissab
    • Dec 2009
    • 2
    Just a Quick Hello
    Just wanted to nip in after joining and say hi to everyone on the board. - Look forward to reading the conversations here!
      Re: dome rings combining with chimney brick
      Is it best to custom cut each of these bricks to fit in line with the dome?
      You can do this either way. You may get a better fit if you match each corner brick, but the easiest way is to build the entry arch first, then butt the bricks of the dome up against the arch. In either case, it's near impossible to get a Guastavino-like intersection between the two, and you will end up with some mortar filled gaps.
      • pizza_bob
        • Apr 2008
        • 181
        Dmun,
        It probably took me longer to complete my dome-to-arch transition than it took Guastavino to complete the Queensboro Bridge Bridgemarket in your photo!
        http://www.fornobravo.com/forum/8/pi...d-7155-10.html
        ~Bob
        My Oven Progress: http://www.fornobravo.com/forum/f8/p...uild-7155.html
        If you fail to plan, you plan to fail!
        • SCChris
          • Jun 2009
          • 1213
          It was the arch first for me. Just take your time, do your best and re-cut if you need to. The structural integrity is what you’re after.
          Remember, that when it's finished nobody will see this area and I've heard no one say that it affects the taste of the pizza one way or the other.
          Chris
          • nissanneill
            • Apr 2007
            • 1886
            Hi smithgardens,
            With my build, I first built the face arch and chimney void and then lastly the Pompeii dome. This was much easier this way because you already had a very solid face to cut the chamfer (on the back of the actual oven entrance bricks) with an angle grinder and then cut your dome course bricks to lay neatly up against the chamfered transition line. It provides a much easier transition and also stronger that merely a vertical join.
            Neill’s Pompeiii #1
            Neill’s kitchen underway
