I'm about to resume enclosing my oven. I am planning a walled enclosure with cement board covered with some sort of stone veneer. Some questions have come up regarding the decorative arch.
I have a double arch fire brick entry in to the oven. I plan a decorative arch in front of this. Does this arch get mortared to the firebrick, or is there an expansion joint/gap of some type here?
The brick I plan to use should match my house brick, and is smaller in size than the firebrick. I also plan to drop the decorative arch about 1/2 inch below the firebrick arch, hopefully helping with smoke draw. As a result, the firebrick arch sticks up quite a bit higher than the decorative arch. I plan to put a hardiboard face on the enclosure. Can this board come close to or in contact with this firebrick arch?
Let me know if this doesn't make sense.
