Things are moving along, taking a little time out from cutting brick to do some planning for the enclosure. I was originally planning a fairly traditional gable type enclosure but decided I wanted to keep the overall size of the oven as small as possible which led me to consider the "igloo" style. This is a mock-up of my current thinking, what I hope will eventually be a geodesic galvanized sheet metal enclosure (maybe copper
I'd like to have a fairly water tight cover for the oven which this should accomplish, also, I think I'll be able to back fill with 3 or 4 inches of loose vermiculite over the 2 inches of blanket insulation I'll be using. I really like the look of many of the stucco domes out there, I'm just concerned that with our weather extremes here that the stucco will be hard to maintain or just may not hold up well.
I haven't come across any discussion of this type of self supporting enclosure, maybe there's a reason no one does this? (aside from all of the sheet metal work) Any thoughts would be greatly appreciated.
Holiday weekend coming, ready for 3 straight days of oven building!
Thanks, Doug
) I'd like to have a fairly water tight cover for the oven which this should accomplish, also, I think I'll be able to back fill with 3 or 4 inches of loose vermiculite over the 2 inches of blanket insulation I'll be using. I really like the look of many of the stucco domes out there, I'm just concerned that with our weather extremes here that the stucco will be hard to maintain or just may not hold up well.
Thanks, Doug
) A continuous copper surface sure would look nice though.
