I have my stand complete and ready to begin building the oven. My concrete/vermiculite layer is 8" thick. It is encapsilated on each side by regular concrete. The one issue I have is it seems to crumble off fairly easily. I realize it's just an insulating layer so strength is not that big of an issue. It's compression strength seems to be fine. (will compress if pushed in firmly).
My question is what can I use to smooth the insulating layer and adhere the brick floor to it? I figure the regular fireclay mortar mix but am not sure what thickness (standard 3/8" mortar joint?)
Is this regular behavior? I used the the recommended 1:4 ratio of concrete mix to vermiculate
