So i just finished the vermiculite layer and am about to get started placing the bricks on top of it. Unfortunately, this is my second time doing this part of the process because my last vermiculite layer did not hold together well enough. I have since then fixed that problem but and still unsure of how the next part of the plans is supposed to work. As i understand it, a thin layer of fireclay is mixed together and then the bricks are set in that making sure that they are all level. What i do not understand is how come this layer does not dry and harden. Is that supposed to happen? Secondly, if it is then wont all my bricks get messed up when i put the first layer of the oven wall on top of them? If anyone could just explain this part of the plan in more depth and detail than the online plans state that would be amazing.
lou
lou
