Okay then,
I had great luck with my mortar, my brick cutting and laying up the first seven chains. Then came number eight.
You guys don't talk much about that point at which the angle is so steep you have to hold the bricks in place while you are mortaring them up.
... or the back pain associated with bending over a huge half sphere trying to hold a brick in place that is covered with sticky mortar while grabbing something to lean against it.
Yes, it's true, I am not the pristine oven builder that most here seem to be, dang! I would love it to work out perfect, and I want my arches to be almost self supporting ( no real work done by the mortar) but when I smear them with mortar, I usually have to get out the rubber mallet to persuade those wedges into a reasonable arch.
Anyway, after one last chain of ( not so easy) leaning 1/2 bricks, I was faced with the choice of going to 1/4 bricks, 1/3 bricks, or just arching over the top left to right, then maybe again front to back, and ending up with a sort of series of spans up there, and 4 last holes to plug with a triangle piece.
Tonight I tried both options and chose the latter. Arching across the top with about 5 1/2 brick wedges. After one somewhat successful one in the middle, I went ahead and made an arch on either side of that, and it was MUCH easier that cutting bricks into 3 or four pieces and trying to taper them at the same time.
Thoughts?
For my arches, I figured, ( I mean across the top of the dome) even if they aren't perfect, the inside will be rarely if ever seen, and the outside will be completely covered with insulation. I probably have some mortar voids, and that may be a concern... I don't know enough about how this mortar acts over many years and many firings.
... I have seen both ways ... smaller bricks in the top chains, and arching across... what did you do ( those who have finished)
( my progress can be seen in my photo album on my profile page)
For all my arches so far, I have just used a 2 1/2" strip of either 1/8" tile board, or 1/4" masonite and clamped on either side of the dome edge with a 'quick grip'. It works SO easily, and the tapered angle ( for my 39" inside diameter oven) of 4" and 5" follow the curve pretty exactly. ( Okay, most of your 'exactly' standards may force me to reword that...) But, if I were using a saw, it would be an absolute snap to get these arches VERY close with this extremely quick and easy technique.
Thoughts?
Enjoy the ride and again, your ovens looks quite fine, please keep up the pics, -Dino
