Here's the #2 taper-brick arch. It is 8 1/2" high and 15 1/4" wide. If I raise the arch with a standard firebrick and a split I will hit a perfect 12 1/4" height for the opening. 63% for a 39" oven is 12.285"
I have two questions:
#1. I want mortar to be as thin as possible to keep the dimensions. How thin can I wipe the mortar in and still make a good bond?
#2. The 15 1/4" width is a bit less than what I was hoping for. The plans call for an 18-19" opening width. Should I fuss with the arch and add a wider keystone at the top, or should I grab the perfect arch width and call it a day?
Lars brought up a good comment about workability. I made a mock up duct tape peel and took a 13" pizza pan and tried it out.
Seems to me to be enough room. Yes it's tight, but I think manageable. How do I know, I've never cooked a pizza in a brick oven
I love bread too so maybe better with smaller opening to retain heat. Does a smaller opening retain that much more heat?
Cast your vote
Cast your vote
