Hi everyone, I think I've read every "crack thread" on the forum so I know this is to be expected, still shocking when it happens!
I have been curing with small fires over the course of a week. A small hairline crack appeared in the arch after the 3rd day, as I kept increasing the size of the fire the crack would gradually get larger and always close back up. Last night, it opened up quite a bit more, maybe 3/32 (2 mm) and I was surprised this morning to find that it had not closed back up. I can only guess at the dome temperature, but this was still a relatively small fire, the floor thermocouple got up to about 350F, after the fire was out. I have been taking it quite slow, my original plan was to cure slowly and add the insulation about half way through the curing process. So, I'm about the halfway point now, and considering what to do next. The crack goes through the arch on one side, up the dome and all of the way around and is working its way back through the other side of the vent arch.
Any thoughts are greatly appreciated as usual!
Doug
Doug
