I'm trying to determine how to best keep my oven dry for the remainder of the build. To date, I've simply covered my oven with a tarp at the end of the day.
However, it doesn't seem like I'll be able to remove the chimney once I begin applying the vermiculite/cement insulation. After that dries (which I think will take a few weeks), I plan to add stucco and stucco paint.
Finally, I'll pour more concrete to raise the counter, and at that point, it should be waterproof.
So...what have others done to keep things dry once the chimney is attached, and before waterproofing is complete?
Thanks,
Stephen
Thanks,
Stephen
