Re: Matt's WFO Build
I agree with Joe. 20 gauge is fine.
They say the 2x4 steel studs are not for load bearing (read exterior) walls. But...remember, those statistics assume a standard 8'-10' tall stud wall. Your studs will be less than 3' (probably) which makes that 15" or 18" stud spacing you'll have A LOT STURDIER than if they were 10' tall.
I put my studs 16" apart then added an extra stud just anywhere on each of the 3 sides (obviously not the front oven side, they are already close) and your walls are now nicely over engineered.
