Is it ok to leave the blanket unprotected for a while? Or should I put a tarp on that sucker when the rain comes?
FB Blanket Weatherproof?
Tags: None
Re: FB Blanket Weatherproof?
I would put a tarp over it.
I agree with the above replies. Insulation needs to be as dry as possible to work efficiently. If you get it wet, it might degrade, compress, grow mold, or just take a very long time to dry out. Yesterday, I went so far as to cover my insulation with aluminum foil before applying wet stucco, to keep the insulation dry. Good luck!
Stephen
San Luis ObispoStephen
San Luis Obispo
"Pizza is suffused with the good feelings everyone has because they're together," Chris Bianco of Pizzeria Bianco.
My Picasa Album
