Hearth Insulation FB Board / Vermicrete
  • Hearth Insulation FB Board / Vermicrete
    I poured my hearth structural layer last weekend and it turned out perfect. 4? of heavily reinforced (1/2? rebar on 6-inch centers plus wire mesh) 5500 psi concrete. Now I am getting ready for the insulating layer. I have already purchased 5 cubic feet of vermiculite and was planning on mixing up some vermicrete next weekend. However when browsing the Forno Bravo store for supplies, I ordered three sheets of 24?x36?x2? FB Board ($ouch$). So the question is?..
    Should I go with just the FB Board or do I need to put a thin vermicrete layer (1? to 2?) on top of the FB Board? Not necessarily for extra insulation, but to fill the gap between the edge of the FB Board and the edge of the hearth. As shown in attachment:
    Re: Hearth Insulation FB Board / Vermicrete
    Unless you don't have enough board to go under your oven, there's no need to fill around the insulating board with vermiculite concrete. The goal is to completely surround your oven with insulation: additional outboard from the oven/insulation profile won't do any good.
      I guess the question that I am asking is does it have to be one (FB Board) or the other (vermicrete)? Does anyone use vermicrete over FB board?
        Hey Nabber,
        A few builders have done that, though it might be overkill -- plus you have to work with two materials. If you are really serious about floor insulation and plan on having really, really long parties, you should put the FB Board on top of the vermiculite, as it is the more efficient material between the two.
        Still, for most cases, the standard 2" FB Board is more than enough insulation, and is roughly equal to 4" of vermiculite concrete.
        Pizza Ovens
        Outdoor Fireplaces
          I used the 2" FB board on my oven build - it works great! Easy to cut and I was able to start placing my oven floor bricks immeadiately after installaion. No need to wait for Vermicrete to cure.
          I covered the oven with the FB ceramic insulation (had enough for 2 layers). Then poured loose Vermiculite in after I finished the enclosure so the entire oven is wrapped in an insulation cocoon.
          Christo
          My oven progress -
          sigpic
            OK thanks.
            I guess that I have been stuck on the vermicrete idea for such a long time (poured my foundation last September) that when I switched gears to thinking about FB Board, I was temporarily confused. THe FB Board should be here this Saturday. I cant' wait.
              If I were to build my hearth again, I would use 3-4 inches of vermiculite, covered with a 2 inch FB board.
              Stephen
              Stephen
              San Luis Obispo
              "Pizza is suffused with the good feelings everyone has because they're together," Chris Bianco of Pizzeria Bianco.
              My Picasa Album
