Texas 42
  • Roadkyng
    • Jan 2009
    • 77
    Texas 42
    Got the soldiers up today. Was harder than I thought as I had to reset the first 3 or so bricks over 4 times before I got them right. Using Lars' mortar recipe which was a definite plus as it doesn't set as fast as Heatstop or the FB mortar does. Gave me time to get my head right. Even so it's not perfect as I have a few bricks that are gapped back from the edge of the floor. (ie the face is not completely flush with it's neighbor brick). That was the hard part was getting the mortar compressed to ensure good adhesion while trying to line everything up.
    I have to keep reminding myself this is a wood burning dome oven and not the space shuttle. Still, my Grandfather (God Rest) impressed on me the idea of craftsmanship in everything you do. Wonder if he ever laid brick....
    PS - tried to upload pics but kept getting a failure msg. Anything special I need to do? - GOT IT!
  • geisen
    • Jan 2009
    • 217
    Re: Texas 42
    Click on Go Advanced.
    Click on the paper clip.
    Make sure your photos aren't too large.
    Click Browse.
    find photo
    Click upload
    click close window
    Click Post reply
    Greg Geisen
    Chula Vista, CA
    Click to see my Thread:
    http://www.fornobravo.com/forum/f8/g...iego-6169.html
    Click to see Google web album:
    http://picasaweb.google.com/gpgeisen...eat=directlink
    • Roadkyng
      • Jan 2009
      • 77
      Re: Texas 42
      Thanks,
      I had done all that while trying to post but your response told me the images were too big.
      Click Browse.
      find photo
      Click upload
      click close window
      Click Post reply
        Re: Texas 42
        Get irfanview (if you are on a pc). It's free. One click resizing.
        IrfanView - Official Homepage - one of the most popular viewers worldwide
        • Roadkyng
          • Jan 2009
          • 77
          Re: Texas 42
          Thanks dmun.
          I used the Windows XP powertoy ImageResize and got it fixed.
          • texassourdough
            • Nov 2006
            • 1719
            Re: Texas 42
            Hi Roadkyng!
            Where are you in Texas?
            Jay
            • Roadkyng
              • Jan 2009
              • 77
              Re: Texas 42
              I live in Talty, a small town between Forney and Kaufman, about 45 miles east of Dallas
              • Dino_Pizza
                • Feb 2008
                • 1036
                Re: Texas 42
                Looks good Roadkyng. Your mortar joints look like mine in your pics. It always seems not perfect working up close but as you said, it's not the space shuttle but it will hold the dome together & your insulation will hold the heat in. Good job with the soldiers around the dome and the angle cut on top to get your dome going. Can't wait some dome rings go up.
                My Oven Costs Spreadsheet
                My Oven Thread
                • Roadkyng
                  • Jan 2009
                  • 77
                  Re: Texas 42
                  Thanks a bunch Dino. Eases my mind a bit hearing that from you since I am using your oven and Lar's as my guide.
                  Did you use a variation of the indespensible too? I built one and have found out the angle of the first course will not line up with the tool bracket. It needs a steeper angle. I believe it is because the fulcrum is approx 1" higher than the floor due to the thickness of the plywood it is bolted too and the height of the eye bolt. I can bend the bracket to get everything lined up but am not sure if it only affects the first course or all of them. Can't see bending the bracket back and forth too many times.
                  • Roadkyng
                    • Jan 2009
                    • 77
                    Re: Texas 42
                    Pics showing my angle problem with the tool. I believe it is due to the added height of the fulcrum. Not sure but was wondering in anyone else had this issue.
                    Pic 004 shows the tool bracket is at the correct angle if the chain brick is resting on the soldier. (Soldiers are cut at 17 degree angle)
                    Pics 011 and 012 shows the mismatch between the tool bracket and the chain brick, when the brick is shimmed to correct angle.
                    My question is will this be consistent all the way up. If so I'll bend the bracket. If not I may have to come up with another solution
                    • Dino_Pizza
                      • Feb 2008
                      • 1036
                      Re: Texas 42
                      I did NOT use an "indispensable" tool. I see what you mean about the fulcrum location and it's effect. Someone else will have to tell you if you have to adjust the angle at each course. I used a stick on a pivot that was about 10" long. The pivot made my dome consistently round, but I just eyeballed each bricks 1" or less distance from the pivot. Since my method worked satisfactory, I think yours will be even better.
                      Still...your pics show a real tight and accurate build. I can appreciate your attention to detail: it will make the final oven quite nice, even with minor adjustments along the way.
                      -Dino
                      My Oven Thread
                      • geisen
                        • Jan 2009
                        • 217
                        Re: Texas 42
                        I used the indispensable tool with great success. My pivot was probably an inch lower than yours.
                        suggestion: trust the tool but cheat.
                        Stand the tool straight up.
                        measure the height from the plywood to the bracket and add a half inch for the plywood.
                        This is how high high your dome will be if you follow the tool as is.
                        since your radius is 21 and your pivot is about an 1 1/2 inches off the floor your probably looking at approx 22 1/2 inches.
                        count the threads per inch on you tool. assuming you want about a 21 inch dome height, you want to shorten the toll by 1 1/2 inches by your last course.
                        Since you have about 10 courses to go. Multiple the number of threads per inch, by 1 1/2 and divide by 10. probably about 2.
                        So each course shorten your tool by 2 turns and it will slowly bring each course in.
                        I did something similar cuz I just wanted a shorter dome height.
                        regards
                        greg
                        Greg Geisen
                        Chula Vista, CA
                        • Roadkyng
                          • Jan 2009
                          • 77
                          Re: Texas 42
                          Thanks Greg. Gotta dust off the geometry skills....
                          • Roadkyng
                            • Jan 2009
                            • 77
                            Re: Texas 42
                            Got the 1'st chain done today. Really interesting watching the firebricks fiz when you first put them in the soaking bucket. I really like the homebrew mortar. Easy to work with and sets well. I do have a bag of Heatstop 50 I will switch to when I get to the upper chains. I figure it will be nice to have something that sets quick for the bricks that need held in place until they set.
                            • Roadkyng
                              • Jan 2009
                              • 77
                              Re: Texas 42
                              Spent the day on the saw. I have discovered that most of the time building one of these things involves hours on a brick saw getting covered in a fine mist of water and brick dust. Cut several bricks up for chains then moved to the inside arch. Dry fitting everything first then will have a 'mortar day'.
