Fio's 35" Oven
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    #46
    Re: Fio's 35" Oven
    Sweet job. Excellent.
    How big were the copper sheets, and is this something a homeowner could do -- if they had the time and materials? I can see other folks wanting to do this.
    • DrakeRemoray
      • Mar 2006
      • 1215
      #47
      Re: Fio's 35" Oven
      Looks great Fio. Did they coat is so it would stay shiny, or will it get a patina?
      Drake
      My Oven Thread:
      • Fio
        • Apr 2006
        • 166
        #48
        Re: Fio's 35" Oven
        The copper comes in strips about 12" wide. There's a fair bit of cutting, bending and crimping to do, but it's not beyond the means of anyone who builds a brick oven.
        There are also other components, i.e. sheets to wrap the chimney, center ridge, etc.
        The real challenge will be to find a dealer for the stock.
        • Fio
          • Apr 2006
          • 166
          #49
          Re: Fio's 35" Oven
          Drake
          It will get a patina, in about 10 years (right about when I do)
          • DaveHI
            • Jan 2007
            • 46
            #50
            Re: Fio's 35" Oven
            if you want to speed up the patina you can hit it with a dilute acid solution. Hydrocloric should give you a green patina. We're close enough to the beach to get enough sea salt to get some green.
            • ljanmi2
              • Oct 2005
              • 18
              #51
              Re: Fio's 35" Oven
              Looks great!
              What was the gauge/thickness/weight of copper that you used?
              I beleive that is sold in thicknesses described as weight per square foot, something like 3oz, 6oz, 12oz,..
              • Fio
                • Apr 2006
                • 166
                #52
                Re: Fio's 35" Oven
                Originally posted by ljanmi2
                Looks great!
                I don't know. If I were to guess, it's about 1/32" thick. But it's soft so it's easily bent.
