Oven opening size
This is a sticky topic.
  • Greenman
    • Feb 2013
    • 1123
    #61
    Re: Oven opening size
    Hi Frank - The 'vermicrete' insulation is just vermiculite and cement. A ratio of 8:1 by volume works ok.
    The trick is to get the moisture level right and too much water is an issue. It will end up like wet rice bubbles and is not a 'fun' material to work with. I found that working from the bottom up, balling it up and applying it in one 'smear' and moving on worked for me. Messing with it after you place it caused grief in the form of crumbling away.
    I had chicken wire over the blanket and it helps hold the vermicrete too. It is perfectly stable once it hardens but I found it an 'interesting' medium. I did, however, use it on subsequent builds.
    By the way, it is best to mix it in a barrow with a hoe rather than a mixer. The vermiculite maintains its integrity that way and you can better judge the moisture level. Good luck with it.
    Cheers ......... Steve
      • 9216
      #62
      I've found the correct ratio of water is 3 parts water for every 10 parts vermiculite, although if you have the fine grade you need more water. As the addition of cement decreases the insulating capacity drastically I use a 10:1 mix, vermiculite, cement. Any less cement than this makes it difficult to get a good workable mix. Adding a little powdered clay to the mix will help to make a lean mix more workable.
      • FrankHawkins
        • Mar 2015
        • 14
        #63
        Cheers thankyou!
        Also I'm building the chimney vent out of bricks. What size would be best to make the internal diameter of it.
          • 9216
          #64
          Originally posted by FrankHawkins
          Cheers thankyou!
          Depends on the size of your oven.
          A 24" oven needs 20 sq in
          A 30" oven needs 30 sq in
          A 42" oven needs 50 sq in
          • FrankHawkins
            • Mar 2015
            • 14
            #65
            Ok, I think it's 8x5 inches at the moment. So I may have to open it up a little as mine is a 39 inch oven.
            Here are the pictures of my opening. Does it all
            Look about right?
            • FrankHawkins
              • Mar 2015
              • 14
              #66
              From another angle.
                • 9216
                #67
                Look about right?
                That's ok, just make the cross section of the chimney a little bigger. The restriction at the bottom where the smoke enters will just work as a venturi making the smoke accelerate at that point.
                • madhatter1138
                  • Apr 2015
                  • 11
                  #68
                  Building a 32" oven. Dome height is 16". Oven opening is arched. 12" in the centre arched to 9 1/2" to the sides. Width is 18". I'm worried that height (at 75%) is way off the mark. Should be around 10.5"...BUT if I add a row of half block then it gets really tight on the ends...
                  Any thoughts? Apparently I missed the 63% rule in the plans!? I figured it was ball parked etc etc...
                  I only looked into this today after completing the arch and it just looks to big....
                    • 9216
                    #69
                    Don't sweat. It makes far less difference than many people would lead you to believe. Just fire your oven as it is, you'd find no noticeable difference if you rejigger it to 63%
                    • madhatter1138
                      • Apr 2015
                      • 11
                      #70
                      Glad to hear this! Since its arched from 9" (not 9 1/2" like I said earlier) to 12" I can take comfort in the math that it averages out 10 1/2" of height..which is right on the money
                      • Phartog
                        • Jan 2026
                        • 28
                        #71
                        I am building a 80cm/32inch oven. Dome height is 42.2cm/16.6inch. I was thinking my Arch entry/opening was not the correct size. My plan has a hemispherical door opening:
                        - width of 45 cm / 17,7 inch
                        - height of 22,5 cm / 8,9 inch​
                        The Pompeii_dome_calculator excel states I should have an opening of 26,6 cm at 63% of the dome height.
                        So I was wondering 2 things. Is my door width not a bit too large for the size of the oven? Because I have a hemispherical door opening, if I want to get the correct door height, I would need to lift the hemispherical opening on some flat bricks, am I right?​ Or would the lower height of 22,5 cm be enough?
                        My WFO build thread: 80cm/32inch WFO build in Rotterdam/The Netherlands
                          • 5264
                          #72
                          The 63% rule is a rule of thumb. The current arch height (53.3%) is more towards a low dome arch ration than a hemisphere oven. I would increase height if you can. Width is more of a builder's choice.
                          • Phartog
                            • Jan 2026
                            • 28
                            #73
                            thanks for the reply, I will increase the height!
