Last night we put up the closet in the back and the back and side wall. We set the ridge board and tonight if we get to play we will put some Durorock on the inside to cut the corners behind the dome against the back of the closet which will shorten the distance between the 2 so we don't have to use so much vermiculite. There is approx 12" and that is just too much waste.
After that the rafters might be going up as well.
G
G
