Edit: retitled thread to reflect actual design.
I'm mulling over my design and almost ready to lay the solider course. Any major problems with these dimensions?
36 inch round. 17 inch interior height. 12 inch sldier course. 5 inch dome rise. 10 inch opening x 18 inches wide.
I've considered a lower dome at 14.5-16; working off of a 9 inch upright soldier. Higher might be nice to avoid the dome transition. But, I am not against that at all. I'll do what is considered ideal.
I'm after a flatter dome for pizza's, flat breads and shallow pans. Although, the smaller opening height makes me curious about getting inside after it is done (if needed). It will be a tight squeeze.
I have no intention to put a turkey inside. The only part that is certain is the 36 inch diameter constraint. The hearth is in the corner of the outdoor kitchen area.
Any advice is appreciated.
