Should one make the outside arch slightly bigger than the inside arch.
arches question
Re: arches question
That's what I did. You want a reveal on the inside arch to fit a door against. If the outer arch is not slightly larger, the door will fit to tightly before you can fit it up against the inner arch.Joe
