i think you are going to need the angle iron. i wish i would have taken a picture when i did mine. it's a little tricky. i have posted a sketch of how i did it at <http://www.cpsusa.com/ebay/angleiron2.jpg>www.cpsusa.com/ebay/angleiron2.jpg (as viewed from the top).*
you need two pieces of iron. an angle iron and a flat piece of iron (i got mine at home depot).*i cannot imagine how to cut the angle irons without an angle grinder. (maybe someone else has some suggestions re: cutting the iron).**
i completed*the row around the dome except in the area next to the angle iron. the angle iron is about the same height as the row of bricks laid next to it and serves as a brick substitute. the angle iron was placed like a pup tent. you then take a brick and place it on top of the angle iron and the flat iron and then sort of move the angle iron and the flat iron back and forth (towards and away from the center of the oven) until your eyeball tells you that the bricks to be laid on top of the irons will line up at roughly the same height as the bricks on the next row. (try to match the interior top of the bricks, not the bottoms). you then slather mortar all around the angle iron to hold it steady and go have a beer.*
you then come back and begin laying bricks on top and find that you really don't have it lined up too good and then redo it several times. by the fourth beer its starting to look pretty good. for piece of mind i cut a keystone brick to fit as the middle brick in the bricks laid on top of the angle iron because (1) the bricks kept slipping off the angle iron and (2) i needed the arch support given by the keystone to hold them all in place. the rows got a little ugly above the angle iron but by using a little more mortar here and a little less there i was able to even things out withinin a couple of courses.
hope that helps...
bob
----- Original Message -----
From: <mailto:marirose@mindspring.com>kanznenbaumberg
To: <mailto:fornobravo@yahoogroups.com>fornobravo@yaho ogroups.com
Sent: Thursday, October 28, 2004 7:10 AM
Subject: [fornobravo] Problem building a dome
Hi,
I've got a problem... I can't figure out how to place the dome's
firebricks above the opening. I made the opening without a metal
angle. The opening is an arch. Please help.
Stanley
hope that helps...
bob
Hi,
Stanley
