Man, I've read A LOT of posts -- in addition to the Pompeii docs -- about dimensions of the oven. I'm pretty unsure how to proceed and would greatly appreciate some input.
As a quick aside let me pose this question: How tall is a turkey, in a pan on a rack? Obviously, this speaks to the opening height, which then governs the dome height, which then has a loose effect on the dome diameter.
I really don't want a big oven, I'm shooting for 36". My love is pizza and I had planned on a relatively low dome, but on a 36" low dome, the 63% rule dictates a pretty low opening, about 10" to 11" I believe. While I think pizza is my priority, I can imagine we will use the oven for many fun things, including the occasional turkey...so, what kind of constraints does that impose on my design?
Another question: Will I really like pizza from a low dome better than from a high dome? I mean, seriously? Unless I'm the freaking Godfather, will I be able to tell the difference? If so, then please honestly say so, I'm genuinely curious, but, I've never even seen it stated anywhere *what* the difference is. Can anyone explain that?
Final question. Even a tall oven is barely truly hemispherical in theory, certainly not taller than its radius, but this seems impossible to me with the "indispensable tool", if it is centered at the floor center (not at some distance on a lazy susan). With no solider course, the dome would end up truly hemispherical. However, with a solider course, if you visualize it a moment, you realize the resulting oven has a height which actually exceeds its radius. Isn't that a very strange shape for an oven? Yet many people advocate such a construction process. As a rank amateur, I'm confused about this discrepancy.
Sorry for the ridiculously long post. Any advice or assistance is greatly appreciated.
Cheers!
Cheers!
