Re: 3G_'s Build
No pointing of the stone, just a little mortar on the inside to hold it together. I still may not use it. Not sure what to do the outer arch and flue area in if i go the bookleaf bluestone.
Good luck with your arch transition, by far the hardest part of the build!!!
I spent a solid 9 hours on the oven yesterday in the 37 degree heat, man am i cooked.
It looks like i will need two more full ring but this will leave no room for the plug. Should i reduce the last two rings (cut the brick down maybe 15 or 20 mm) so i can get the plug in ?
