FB Blanket
  • KEmerson
    • Jan 2009
    • 204
    FB Blanket
    For a 43" oven would three rolls of FB insulating blanket be enough or too much?
  • Les
    • Sep 2005
    • 2945
    Re: FB Blanket
    I built a 42 inch using 2 blankets. It was 2-3 layers thick and a little more in some places. (I also added some vermiculite on top of that) You can't have too much.
    Les...
    • KEmerson
      • Jan 2009
      • 204
      Re: FB Blanket
      So two rolls/blankets together gave you 2-3 layers, or 2"-3" overall?
      • Les
        • Sep 2005
        • 2945
        Re: FB Blanket
        Yes. Hopefully other will chime in and we can see their experience.
        Les...
        • KEmerson
          • Jan 2009
          • 204
          Re: FB Blanket
          I am planning on adding 6" total insulation on the outside of the oven brick, for a total of 10". I imagine 2" FB blanket plus 4" perlite/cement mix would be about fine. Is this a good ratio?
          Thanks.
          Kim
          • Les
            • Sep 2005
            • 2945
            Re: FB Blanket
            Kim - I think you would be happy with that amount. Are you doing a dome or an enclosure? The reason I ask, if it's an enclosure, don't add the portland.
            Les...
            • KEmerson
              • Jan 2009
              • 204
              Re: FB Blanket
              Doing a dome.
