4" 5" or 6"
  • 3G_
    • Aug 2009
    • 86
    4" 5" or 6"
    How much vermiculite to place under the dome. From memory the plans call for 4",is this enough?
    3G
  • RTflorida
    • Jan 2007
    • 1446
    Re: 4" 5" or 6"
    4" is sufficient, but as we say here....insulate, insulate, insulate. If you can add more without drastically altering your plans, go for it.
    That said, I used 4" (per the plans) and have been totally happy with heatup and heat retention.
    RT
    • Jed
      • Apr 2008
      • 428
      Re: 4" 5" or 6"
      I'm with RT,
      I followed the plans with the 4" and am happy with the results.
      We will cook in the oven the following day for sure after a pizza event, and often even the second day with a long slow cook pot of beans or something similar. The oven holds heat just fine with the 4".
      JED
