Wooden wedges
  • Sipper
    • May 2009
    • 2
    Wooden wedges
    Can you leave the wooden wedges in, or do they have to come out.
  • michelevit
    • Mar 2008
    • 106
    Re: Wooden wedges
    where are these wooden wedges located?
    are they shims to hold up the bricks on the outside of
    the dome?
    maybe atattch a pic so we get a better idea.
    • dbhansen
      • Jun 2007
      • 566
      Re: Wooden wedges
      Normally the shims used in dome construction are taken out and replaced with mortar. Otherwise they'll burn! And the extra mortar makes it stronger.
      Picasa web album
      Oven-building thread
      • kebwi
        • Aug 2009
        • 1090
        Re: Wooden wedges
        You could make your shims out of fire brick I suppose...but that's a lot of very precise cutting.
        • KINGRIUS
          • Aug 2009
          • 113
          Re: Wooden wedges
          I was going to use the wooden shims but I was able to do without. I gobbed extra mortar on the top back of the brick already set and tapped the new brick down 'till it was in position. The mortar was able to hold it without the shim. Then I would spread the extra mud that gushed out the back into all the voids.
          • Roadkyng
            • Jan 2009
            • 77
            Re: Wooden wedges
            I do the same then take a pointing tool to compact the mortar. Haven't had a brick fall out....... yet.
            • cynon767
              • Dec 2008
              • 230
              Re: Wooden wedges
              I tried using shims at first, and abandoned them after the first 2 rings. They were actually less accurate than just shaping the mortar with the trowel by eye.
              -jamie
              My oven build is finally complete!
              • jmhepworth
                • Feb 2008
                • 293
                Re: Wooden wedges
                I also tried using the shims and decided they didn't help much after the first couple of courses. I just put a bit more mortar in than I needed and tapped the brick with the back of the trowel until it matched the string. That didn't work if I got the mortar too wet, but learning how much water to put into the mortar came pretty quickly -- during the first couple of courses.
                Joe
                Joe
                • intelo
                  • Mar 2020
                  • 1
                  Please help!
                  I am about halfway through my built and realized that I left all the wooden wedges I have used between layers thus far ( I am on course 6). I have applied mortar generously in addition to the wooden wedges. The mortar has set pretty hard so I dont think I will be able to go back and remove the wedges? Will I have issues later on as a result of leaving the wedges in? Do you have any suggestions to solve or mitigate this problem?
                  Any suggestions will be much appreciated.
                  Thank you
                  • RandyJ
                    • May 2010
                    • 1191
                    It could be a problem. How big of a problem is a bit hard to say for sure. For future reference you can remove the shims in just a few hours once the initial setup has happened. I used wirenuts for my spacersand kept reusing the same 20 or so over and over. Good luck.
