I want to build a pompeii style oven (I currently have an AS style that I built a few years ago). This will be a pizza only oven. I want it to heat quick and cook extremely well. Is it necessary for the hearth thickness to match the dome thickness? I want to use the FB pompeii plans. However, will 2" FB Board with a 2.5" thick firebrick hearth work well with a 4.5" thick dome covered in 2 or 3" of FB blanket? Or do I need to stand the bricks on edge to give a 4.5" hearth?
Thanks- Mark
Thanks- Mark
