I apologize in advance that my questions are often long and verbose. Such is my way...
My understanding is that the most basic FB Pompeii design is very forgiving of large mortar joints, prescribing an extremely simple half-rectangular block design for the purpose of enabling as many people as possible to build ovens. I admire the motive, but nevertheless have some questions about the assumptions it rests on.
Now, mind you, that for the purpose of this thread, I am not inquiring about the dome's structural strength or problems that may or may not arise from using rectangular blocks with fat mortar wedges as opposed to trapezoidal blocks (on one or two axes) with thin mortar wedges. That is not my concern in this particular thread. Rather, I am asking about the problems that might arise from exposing large (what is large, 1/4", 1/2"?) areas of mortar to the super-heated interior of the oven?
While this may be less of an issue with true refractory mortars like Heatstop and Refmix, and I am going homebrew, and I believe the general wisdom on the subject is (correct me if I'm wrong) that the Portland in homebrew will effectively dissolve away under high heat.
So, does such a problem mean that we should really strive to minimize exposed homebrew mortar on the interior surface of the oven? The most effective way to do this is to angle our bricks not only on the azimuth axis but secondarily on the altitude axis as well, which of course gets into some pretty fancy cutting.
To people who only angled their bricks on the azimuth axis, thus leaving large triangular mortar gaps exposed to the interior: what is your opinion of such an approach after the fact? Does the mortar spall and fall away from the sides and roof of the oven or behave in any other undesirable way?
Thanks.
Thanks.
