I had a piece of granite cut for my oven. The attached image shows the cardboard template I used. I have two questions regarding the installation:
1) What should I use to fill the gap between the granite and the exterior of the oven? I have some high temp caulk that I'll use for the gap between the granite and the firebrick, but I'm not sure what to use for the other gaps (e.g. the brick arch and stucco).
2) I'd like for the granite to have a slight pitch so that any runoff will flow away from the oven. I don't want to simply use shims, as I understand that granite needs to be fully supported underneath. Ideas?
Thanks,
Stephen
Thanks,
Stephen
