I got to check out a 42" Pompeii (style only but not from the FB plans) oven being built by a neighbour with advice from another but unknown person and I informed him that the bricks that he made the dome from were cement pavers, not fired clay pavers and were totally unsuitable for the oven dome construction.
I showed him the difference between cement and clay bricks which was new to him. He also had a new crowbar trying to break up the polystyrene foam mould from inside the completed dome, He is about ready to insulate it and then brick up the entrance void and put in the 8" chimney.
I was looking carefully at his hearth which are fire bricks and asked if he had insulated his base. No, was his reply! Sad news as I explained the consequences and recommended that he demolish the dome, lift his hearth and I would help him build a new insulated floor, relay his hearth and then rebrick his dome.
At this stage, I am not sure of what he will do but I will find out in due course.
It will only be 2 days work and well worth the extra effort now instead of trying to cope with the consequences.
I think that there is a lesson buried deep in here somewhere, join this forum, research your ideas, ask questions, follow a couple of builds and then progress with help from the forum if needed.
Don't have blind faith in some one or something that you have little knowledge about.
