Indoor Kitchen and WFO
  • #16
    Re: Indoor Kitchen and WFO
    So is the implication that the smoke-on-start up issue is unacceptable with a WFO (vs. other woodburning fireplaces) because of the design of the WFO or because of your chimney requirements?
    Chimney issues aside, it seems like smoke on start up is in no way exclusive to a WFO and has as much to do with the method of firestarting and state of the wood used as it does design. Not much different from many current-era fireplaces in that regard.
    If this is the primary stumbling block, I believe one could devise means of mitigating the problem by 1. mimicking to the curved throat and flue design ala Rumford (which many WFO builders have done anyway) and/or 2. devising some kind of a door for the outside arch to keep the smoke contained until draw has been established.
    There are, after all, MANY people who already have successful WFO's indoors.
    I completely hear you on the cost thing, however. I have the advantage of being able to go straight up inside, but it's still ~25' feet straight up.
    • #17
      As an FYI, 30 degrees is the accepted maximum deviation from plumb for a chimney. You can surely fire a WFO without smoke spillover using the same techniques as used for balky fireplaces and rumfords. The key is to get heat into the flue without generating smoke by using a small fire from dry wood.
      • #18
        a smoking oven at only the begining of a fire (and not periodicly durring the fire)tells me that your flue to opening ratio is proably out or the throat is not built correctly in a unit that is allready installed not a lot you can do. try starting your fire as safly as possable to the front of your oven then after it gets going push it to the back of the oven
        you want your out side air vent as close and as un ubstructed as possable to the opening of the oven as possable try submiting one that can be manualy opened and closed upon demand
        what the inspectors/planning dept. will proably be wanting to see is that you did your homework . try looking up the specs for a fireplace that are the same(or close to it) to where it sits in the building as your oven. look for clearances to combustables, air gaps,reinforcement,ties to building, outside air vent ect.
        good luck!
        • #19
          Greetings,
          A little experience to share from Indiana if I may.
          I have built an indoor WFO with the door opening in the laundry room of our old brick farm house. I would have liked to use the shutoff damper such as the ones used on some masonry heaters but I couldn't wait. I decided on installing a chimney top damper which I assumed would work best if the 8 x 12 flue ran directly above the landing area. This assumption was correct but I discovered that the 2 story chimney can hold, and release, MUCH black soot. This soot of course falls directly on the handles of the oven door. And on the landing area. If the chimney had a small amount of offset the soot would still be there but it would not fall on our work area.
          I believe that the moisture of the laundry room may have some bearing on the problem. Last winter during a windy -20 degree power outage the damper stuck which meant a trip up a ladder at 5 am!!
          I have second door which I call the landing door. It slides up into the facade and may help keep some of the moisture from going up the chimney but I am not sure how much it helps.
          On the combustion air.
          Off to the side of the landing area I have an ash drop which dumps into a chamber on one side. (there is still room for wood storage underneath) This chamber has an 8x8 clean out door which can let in some air if we find it to be necessary.
          Keith
          • #20
            Hi Keith
            re: your comments about the chimney soot
            Based on what I've read on fireplace chimney design, the smoke shelf that is common element in WB fireplaces seems to have a somewhat vague purpose/function (suggestions have been that it gives a chimney sweep someplace to stand...), and it seems like your experience with soot falling on your door and landing defines its usefulness to some extent...
            excellent info. thanks for posting!
            would LOVE to see pictures of your indoor WFO.
            • #21
              The purpose of a smoke shelf is to prevent downdrafting, and improve the draw by forming a "roll" of smoke in the smoke chamber.
              • #22
                Picasa Web Albums - Keith - FarmOven has few pics
                • #23
                  That is extremely nice work, and very inspiring. What is the fire door made from? Does it run in some kind of formal track on the sides or is that just a channel in the brickwork?
                  The pulley system you worked in is great. Are those steel components affected at all by the heat? I'm leaning heavily towards a cooking fireplace vs. another WFO indoors and I'd like to incorporate something similar to allow for an Argentinian-style grill.
                  • #24
                    The firedoor and the oven door (with the 2 handles) are both made from a product by Carpenterstone. The version we used is called Xtreme Lightweight and is sold by SureCrete. This stuff is, as the name implies, lighter than regular concrete and is supposedly fireproof. We build a form and just pour concrete.
                    We have had no problems with the heat.
                    The firedoor disappears with the help of a hidden pulley system. There is no significant heat up where the metal pulleys are. The top "mantel" is actually concrete and is removable to access the pulleys.
                    The face of the oven is all concrete, formed and poured in place. I just wanted to try it! Lined the forms with either wallpaper or plastic visqueen to give it the "look"
                    Different is Good
                    Keith
                    • #25
                      Wow that is really an impressive build!
                      My Oven Thread:
                      • #26
                        Originally posted by tdibratt View Post
                        Thanks DMUN. Interestingly enough I had contacted John Gulland (author of that WOODHEAT.ORG). He got back to me and advised against putting an oven in the house. My situation of running the oven in my basement kitchen would have 2 x 90 degree elbows (top of oven back to wall to exterior chimney and then up) and he suggests with the amount of smoke oven's create on start up, that it would likely fail. He suggested a power exhaust fan on the chimney might make it work (additional $1500). The Chimney and exhaust fan will likely be around $6,000 alone (I arrived at this figure using the online Sentinal Chimney configurator and added the $1500). He speaks form experience as he too has an outdoor oven but would not consider one indoors. He also suggested that a WETT certified professional would not be able to pass judgement on the design because an oven is beyond that of a fireplace and chimney and there are no relevant code provisions and suggested I contact the building dept and get more guidance before proceeding.
                        All in all, his advice is very useful. I expected to have some hurdles to get over on this one since ovens are not typical and people may not know how to deal with them (i.e Building Dept). I did contact several WETT certified professionals and not one got back to me. Not sure if they are too busy or just do not want to get involved because of what I am trying to do.
                        At this point the whole idea is somewhat of a turn off for me. Given the cost of the chimney alone and hurdles I need to rethink this and see whether or not I want to pursue. It was a challenging project for me which I was looking forward to.
                        I will keep any additional feedback or progress (if any) posted on this site. Many thanks to DMUN and others for feedback and comments.
                        Regards
                        I am new to this forum and stumbled upon this entry from almost 4years ago. I am considering a basement kitchen WBO from Forno Bravo. I have an identical problem. In order to vent the oven, I would need two 90 degree bends as described above, then a straight run of approx 25-30 ft. The above response is not very encouraging, to say the least. Any opinions?
                        Thanks.
