Hello all, I?m using an air set fire brick mortar from Acme brick. It comes wet in the bucket, and they recommend that it be watered down to the consistency of heavy cream. I did not go that far, and mixed just enough water into it to make it pliable. However, it has been out for a couple weeks now and it has not cured! Not only that, but it has contracted and shrunk slightly between the bricks. Argh!
So, has anybody else run into this, and is it a fatal problem? I have a feeling I'll be dismantling my first two chains, but thought I'd check first. Plus, if the mortar is the problem, what else is there? This wet is all I could find after a bunch of phone calls in the Dallas/ Ft. Worth area.
Thanks for any advice.
