cutting cement board
  • eprante
    • May 2009
    • 282
    I am planning on forming a brick arch for my under stand wood storage. I was planning on framing the corner with hardibacker attached to 1x1. Does the hardibacker cut with a jigsaw- I have never used the stuff before?
    Thanks,
    Eric
  • Les
    • Sep 2005
    • 2945
    Re: cutting cement board
    Eric, normally it's just scored and snapped but there is no reason you can't use a jig saw.
    Les...
    • eprante
      • May 2009
      • 282
      I have heard of scoring and snapping, but I need a curve. Thanks Les.
      Eric
      • fxpose
        • Jul 2009
        • 942
        For curved cuts on cement boards I use an abrasive (no teeth) blade on a zigsaw.
        George
        My 34" WFO build
        • Ken524
          • May 2007
          • 1655
          If you use a standard toothed blade with cement board or hardi, you'll eventually end up with a no teeth blade.
          Ken H. - Kentucky
          42" Pompeii
          • olddude
            • Jul 2009
            • 61
            not teeth than how can you eat pizza
            • Millstone Man
              • Oct 2009
              • 160
              Why don't you use a router a zipsaw? Best way to cut round shapes. Just make a jig to keep you perfectly round. I am in the process of doing the exact same thing (a brick arch for the wood storage). I used MDF as it cuts much easier and I only need it to to hold up long enough for my mortar to dry. I will attempt to post some pics tomorrow but I've not tried adding pics yet. In the meantime you can check out my gallery photos posted in my signature line?
              Scott -
              My projects: http://www.facebook.com/#!/scott.kerr.794
              • RTflorida
                • Jan 2007
                • 1446
                I'm pretty sure you can buy cement board jigsaw blades and they are only a few dollars. I've used a circular saw many times for straight cuts (with a cement board blade) and diamond impregnated holes saws for plumbing cutouts. Cement board circular saw blades are pretty cheap ($10?).....the diamond holes saw are a different story - $20 and up, each.
                Try Lowes or Home Depot for the jig saw blades, I am pretty sure I have seen them, I believe they were from Bosch.
                RT
                • SCChris
                  • Jun 2009
                  • 1213
                  I used the "Alltool 9000" AKA The angle grinder.
                  Chris
                  • Millstone Man
                    • Oct 2009
                    • 160
                    Here is my brick arch under construction with form in place. I do a section and then slide the form down.
                    Scott -
                    • eprante
                      • May 2009
                      • 282
                      Chris
                      Jeez,
                      Why didn't I think of that!! I have one of those.
                      E
                      • Zuccato
                        • Jul 2009
                        • 13
                        I use a jig saw for curved cuts, but it dulls the blade real fast.
                        • meco211
                          • May 2010
                          • 81
                          Here is a couple photos of my form and arch. I just completed it today. I just used a piece of scrape 1 x 10. cut it with a jug saw and screwed a couple pieces of 2 x 4 in the middle.
                          Toby
                          Columbus, NE
                          • robfin
                            • Mar 2010
                            • 13
                            Use a 4" grinder with a diamond blade, and a dust mask.
                            Rob
